Bluray Error Code 25 Not Enough Hard Disc Space
COW Forums : Adobe Encore DVD
Joe Bandy
on Aug 18, 2009 at 9:55:39 pm
I'm trying to make a Blu-ray image on my computer and recieving an error that states:
Blu-ray Error
Not enough free storage, "code 25" Note: Not enough Hard disc space
Now I first thought to check my hard drive but I have plently of space. Next I noticed that encore CS3 was trying to make an image that is 340GB in size!!! Why would it do that? My project only has 4 assets. HELP this is going from bad to worse.
Thaís Cardilli
Re: Bluray Error Code 25 Not Enough Hard Disc Space
on Feb 25, 2010 at 8:46:46 pm
Hy.
I am having the same problem.
you got any progress?
thanks
Thaís
Preet Singh
on Aug 11, 2010 at 4:26:49 am
Hey guys...I just figured out how to overcome the error.
Once you have imported file into timeline.
go to
File>Edit Quality presets
It will take you to the quality preset window.
choose any format you like..MPEG Blu ray or H.264 etc.
Then scroll down to bitrate settings.
I always use CBR, but you can use VBR, 1 Pass or VBR, 2 Pass.
once you select the bitrate encoding.
Adjust the minimum, for VBR > target and maximum bitrate setting.
For CBR, the default is set at 30mbps...bring that down.
It seems that encore uses very high setting for transcoding.
For example: if you have a mpeg blu ray file which is 12gig...once you import it in encore and add to time line. it will show the total size for the project is 26gig....this is because of the Quality presets.
Conclusion: import files to encore and them adjust the quality preset and you will be able to adjust the size of your project.
Take care.
Preet Singh
on Aug 11, 2010 at 6:19:22 am
go to
Conclusion: import files to encore and then adjust the quality preset and you will be able to adjust the size of your project.
Take care.
