Encore Slide Show into Premiere
COW Forums : Adobe Encore DVD
Debbie Mulvena
on Aug 15, 2009 at 4:26:05 pm
Does anyone know of a way to import encore slideshows from Encore into Premiere CS4?
Jeff Bellune
Re: Encore Slide Show into Premiere
on Aug 15, 2009 at 4:34:18 pm
The only way is to find the transcoded MPEG2 file in your project's Transcodes folder and then import that into Premiere Pro. You'll likely have to load a few of those files into a media player to find the right one, because the name of the file won't be what you expect.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Debbie Mulvena
on Aug 15, 2009 at 5:17:33 pm
Thanks so much for your quick response as always you're a tremendous help.
Jeff Bellune
on Aug 15, 2009 at 5:52:04 pm
You're welcome (I think). :-) Were you able to find the appropriate file?
-Jeff
Debbie Mulvena
on Aug 15, 2009 at 9:07:14 pm
Hi Jeff Im struggling. Im cringing as I'm asking..where will I find this transcoded folder???? I've looked and looked..is it right infront of my face.
Many thanks
Mental Midget
Jeff Bellune
on Aug 15, 2009 at 9:51:06 pm
Dear MM,
The transcoded slideshow shows up as a series of .m2v files with strange names in the Sources\Transcodes folder inside of your main project folder.
Join the .m2v files together in a Pr timeline and you can edit them as you please.
Screenshot of what to look for attached.
Debbie Mulvena
on Aug 17, 2009 at 6:38:08 pm
Hi Jeff..Just wanted you to know I finally found the files. I see what you mean!!
Thanks again for your help. I'm sure you'll see my name again as I am going from 8 years of editing on Discreet Edit to PP I am struggling at times. well......most times,,,,
Regards
MM
