Cannot import mv2 file into encore cs4
COW Forums : Adobe Encore DVD
jeff openshaw
on Aug 10, 2009 at 6:45:27 pm
The m2v file works fine in cs3. Cs4 stops loading the m2v file when it reaches 80 percent. When I run the task manager to shut down encore after it freezes up my whole computer freezes and I have to reboot. This is the 1st time windows 7 RC has frozen. Any help would be great. Thanks.......Jeff
Jeff Bellune
Re: Cannot import mv2 file into encore cs4
on Aug 10, 2009 at 7:08:05 pm
How long is the video in the .m2v file? How long did you wait before you decided En was frozen? Does it do the same thing in Vista or XP?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
jeff openshaw
on Aug 10, 2009 at 7:42:30 pm
The file is 615 mbs. I went away from the computer for 10 minutes and no change. I didn't have this problem in XP. I never had vista. I'll try this file in xp then repost.
jeff openshaw
on Aug 10, 2009 at 9:46:06 pm
I tried the same file in XP and it works fine. I tried it again in windows 7 RC and it stopped at 80 percent. After 5 minutes I tried closing the program and it would not shut down. Brought up the task manager and when I clicked on it the computer froze. I could bring it in as a quicktime or avi file.
core i7 920
nvidia 1800fx
windows 7 RC 64 bit
12gigs ram
no over clocking
Jeff Bellune
on Aug 10, 2009 at 10:25:04 pm
Seeing as how Windows 7 RC is beta code, and not even the same as the RTM version, and seeing as how CS4 isn't supported on Windows 7, and seeing as how it works in XP, then I would have to flag Windows 7 as the underlying problem.
-Jeff
jeff openshaw
on Aug 10, 2009 at 11:20:00 pm
I think that may be the case. I have xp as the backup system on another drive so I'll use that until full release of windows 7 in Oct.....Thanks for your reply..Jeff
Augusto Pirrone
on Jan 7, 2010 at 8:01:14 pm
Hello, i'm facing similar problem.
Encore CS4
Windows 7 Final (build 7600)
Asus P5Q
Intel Q6600
2GB DDR2
ATI Radeon HD4850
When importing a MPEG-2 file as timeline, it freezes everything at the point the music seems to be ralentized (but stil playing, slowly) and cant move the mouse or open the task manager.
The video is 1 hour and 10 mins long and weighs 4GB. I didnt tried many thing because is very frustrating to hard reset the machine every time it freezes.
Has anyone else tried to do thi with Windows 7? Or its a solved problem on W7 and im facing another problem?
santos alvarado
Re: Can not import the file into a mv2 CS4
on Feb 13, 2010 at 6:40:01 pm
Adobe premier CS4, M2v file when I import file. The time line, Ay dew freezes, Problems which cause me to edit.
My laptop, Has these features.
Windows 7
Hp dv7-2185
Intel Core2 Quad Q9000
6mb cache
6gb memory
500gb HDD
Ati radeon hd4650
Someone could tell me what is happening, And how to solve.
Adobe Encore CS4. I open it starts loading and then cut, Error is not compatible with Windows 7
Someone has that problem?
http:/ / farm5.Static.Flickr.com / 4030/4354119072_fa0fe93059_b.Jpg
Brenny boy
on Apr 10, 2010 at 12:30:48 pm
I have CS4 Encore and cannot import an m2v file. It gets to 80% and the whole System hangs. I have tried to close it down using the task Manager but to no avail as even the mouse has frozen.
I have windows 7 Professional 64 bit and 6 mb memory.
I have created a High definition Blu ray project Mpeg 2 50p
the m2v file and .ac3 are 21.5gb in total.
Is there a fix for the import problem. I would appreciate if anybody
can help me with this problem. I had CS3 and Windows Xp and it wasn`t a problem with the import.
many thanks in advance.
Jeff Bellune
on Apr 10, 2010 at 12:59:37 pm
Try this:
http://forums.adobe.com/thread/398761?tstart=0
It may help. It may not.
-Jeff
