text in subpicture highlight
COW Forums : Adobe Encore DVD
Enginn Heima
on Aug 8, 2009 at 9:29:45 am
I'm trying to do the simplest thing. Having a text in button subpicture highlight, so that once the button is highlighted a text appears below.
Ok, it work, but the text is really ugly. Read on the forum that it's because of the lack of anti-alias and that the subpicures can only handle unicolors.
STILL, IS THERE NO WAY OF DOING THIS WITHOUT HAVING THE TEXT APPEARING LOOKING LIKE HELL?
Jon Geddes
Re: text in subpicture highlight
on Aug 8, 2009 at 4:08:34 pm
Use a font that looks good, typically this will be a sans-serif font. Button highlights are only 2 bit. So the pixels are either 100% opaque or 0% opaque, there is no smooth edge. Of course you can always make the entire button semi transparent in Encore, but that still doesn't change the edge smoothness. It is a limitation of the DVD spec, not encore.
Jon Geddes
http://www.precomposed.com
Enginn Heima
on Aug 8, 2009 at 7:46:33 pm
Thanks Jon.
Tried the Sans Serif, but it doesn´t look good enough. I guess, as a general rule, YOU SHOULD NOT USE TEXT IN SUBPICTURE. Not cool.
