interlaced or progressive
COW Forums : Adobe Encore DVD
Sergio Barrozo
on Jul 30, 2009 at 6:44:55 pm
When I export a movie in Premiere (CS3)to later import in an Encore project, I always export from Premiere as avi (interlaced - lower field first) that´s the default.
I notice that when I run the DVD in a TV set, the image is ok and runs smooth. But when I run the DVD in a computer, the line fields appears in images with movement and the captions and lettering are somehow jagged.
What´s the best setup to export a movie from Premiere to Encore in order it can play ok in a computer and in a TV set?
Jeff Bellune
Re: interlaced or progressive
on Jul 30, 2009 at 7:32:53 pm
Your software DVD player is at fault here. A good software DVD player will deinterlace the footage for computer playback so that you don't see any interlacing artifacts.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
