Reset Chapter Markers
COW Forums : Adobe Encore DVD
Paul Benson
on Jul 22, 2009 at 4:48:06 pm
Using the CS4 suite...
I had to update some chapter markers in PPro. I then opened Encore and 'Reverted' the appropriate asset (which was Dynamic Linked). Looked like it worked, since the length of the asset matched my latest changes; however, the chapter points, which I had modified in PPro did not get carried over into Encore. Encore still has the old chapter point times. Is there a clean way to refresh those chapter points? Probably easier to remove the asset and add it back rather than moving all of the markers.
I found something similar in the Adobe forums:
http://forums.adobe.com/thread/440419;jsessionid=79BC895E8E07DF60B0109E011B...
but it claims that issue is fixed with the latest update (which I have), but I must have a different issue.
Pauley
Joe Bowden
Re: Reset Chapter Markers
on Jul 22, 2009 at 5:58:11 pm
Duplicate your timeline (for safety), and then delete the asset from it - the chapter points should disappear.
Drag the DL asset back into the timeline - do you have the latest chapter points?
Paul Benson
on Jul 22, 2009 at 6:22:41 pm
Yep, that is the work-around I ended up doing. The first time, though, it decided to crash Encore, but it worked the second time. Had to relink my menu buttons, but I didn't have that many.
Pauley
