Determining size on disc
COW Forums : Adobe Encore DVD
Amit Zinman
on Jul 20, 2009 at 4:28:52 pm
When I check the project, Encore notifies me that my project is to big for DVD. However, I can't tell how much each item weighs.
Though Encore can tell me the size of objects, it doesn't divulge the actual final space on disc.
Am I missing something?
Amit
Joe Bowden
Re: Determining size on disc
on Jul 20, 2009 at 5:00:06 pm
Yes, check the Build panel. There's a disc usage gauge there.
Amit Zinman
on Jul 20, 2009 at 5:04:02 pm
but it doesn't tell you what weighs what
Joe Bowden
on Jul 20, 2009 at 6:33:04 pm
Take a look in the Project panel...there's a Size heading there that shows the size of each asset (you may have to scroll right to see it).
Paul Benson
on Jul 22, 2009 at 4:49:28 am
Try going to File->Edit Quality Presets.
From that window you can choose which video clip (bottom left drop down) and then the different compression settings. On the bottom right it will tell you the estimated file size.
Note that as far as I can tell, this does not change your transcode quality (which I originally thought it did). To do that, you need to choose File->Transcode Settings for each clip.
Pauley
