"Edit Quality Presets" goes back to default
COW Forums : Adobe Encore DVD
Roy Messinger
on Jul 7, 2009 at 11:51:06 am
Hi, I am going to make a DVD with some standard mini dv clips.
After opening a project with DVD authoring mode, I open the File - "Edit Quality Presets" and on the right side of "Export Settings", I choose "Format" - Mpeg2 DVD with default "Preset" then hit OK.
When I come back to this "Export Settings" window again, all the settings return to the defualt.
Am I missing something ?
Thanks in advance.
Roy
Jeff Bellune
Re: "Edit Quality Presets" goes back to default
on Jul 7, 2009 at 1:40:12 pm
You have to save your changes by saving and naming a new preset.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Roy Messinger
on Jul 8, 2009 at 6:28:43 am
I did it a few times. Still, whenever I open the quality presets, it shows the default blue ray, or it shows VBR 2pass, even if I save another transcode.
Is it some kind of bug, maybe?
Jeff Bellune
on Jul 8, 2009 at 1:35:52 pm
Sorry. I misunderstood. I thought you were having trouble saving the changes you made to the settings.
If I understand correctly now, you want to have the Edit Quality Presets dialog to open up with your last saved/used preset showing instead of whatever default preset Encore chooses to show you. Is that right?
I don't know a way to do that. If it's important to you, please file a feature request here.
-Jeff
