button highlights disappear
COW Forums : Adobe Encore DVD
John Kis
on Jun 22, 2009 at 1:07:40 am
Hello all,
I have a static menu with an audio background. After the audio finishes, my button highlights disappear. I also can't select anything, so the function disappears aswell. Any idea on this one?!
John
Joe Bowden
Re: button highlights disappear
on Jun 22, 2009 at 1:43:01 am
Which version of Encore, and Mac or Windows?
Also, what's the duration & loop point timecodes for the motion menu? (you can find this in Menu properties)
John Kis
on Jun 22, 2009 at 1:58:02 am
Hi Joe,
I'm using CS4 for windows.
The duration for the audio track is 9 seconds, however i have entered 10 minutes into the duration field. The highlights disappear after 9 seconds.
The loop point is 00:00.
I have loop # set to None.
Joe Bowden
on Jun 22, 2009 at 3:42:37 am
Is this happening only in Encore Preview mode, or have you seen this behavior on a burned DVD?
John Kis
on Jun 22, 2009 at 3:45:36 am
In a burned DVD.
Joe Bowden
on Jun 22, 2009 at 2:15:02 pm
OK, so it seems it's not just a preview issue.
I'd reckon that if your asset duration matched your menu duration, you would not see this problem. You might want to try that as a workaround, if you're looking for a quick solution.
If you have a little more time to poke around, you might want to try a shorter menu duration - does the same thing happen if its duration is 15 seconds? If not, find out how far you can push it before the problem shows itself.
John Kis
on Jun 22, 2009 at 9:55:35 pm
Thanks Joe - great advice.
