Error importing Assets "OSStatus Error = -37"
COW Forums : Adobe Encore DVD
David Popper
on Apr 8, 2009 at 1:44:34 pm
I'm running CS3 on my Mac Pro with OS 10.5.6 I created several separate program streams in Compressor and have imported them as assets into Encore...except for one. I've re-exported multiple times and each time I try to import into Encore, I get the error message: "OSStatus Error = -37"
Does anyone know what this error message means and/or how to remedy it? I've done everything the same as the others but this one doesn't work. The file size is less than a gig and i have over 100 gig's available.
Any ideas?
David
David Popper
Re: Error importing Assets "OSStatus Error = -37"
on Apr 8, 2009 at 6:01:19 pm
I'm not sure if this is the problem or not, but I might have figured it out. I renamed to file to make it shorter (thinking that was the problem) still no luck. Then I removed the slash that was in the file name and it seemed to work. apparently Encore doesn't like symbols in the file names. maybe that's what error -37 means - invalid filename or something.
If anyone can confirm or offer a different explanation, that'd be great
Jordan Willox
on Sep 24, 2009 at 9:01:47 pm
Totally confirmed. I had a colon in the name of the disc and it stopped building at the same place a bunch of times.
When I removed the colon... shazam. It worked.
nick kuprion
on Aug 22, 2010 at 5:26:48 am
yep, it looks like that did the trick!!!
It's All About Video...
barold lynch
on Mar 30, 2012 at 12:17:52 pm
brilliant! I love the internet
Chris Beeman
on Jun 18, 2014 at 3:15:03 am
Hi, I'm having the same issue and struggling to fix it..
how did you rename your assets without compromising your links?
