Maximum movie length for good quality
COW Forums : Adobe Encore DVD
Rex Summerfield
on Mar 21, 2009 at 5:07:21 pm
Hi All, I was wondering what you have found is the maximum length of a DV AVI movie you can "reliably" compress and put on a single layer DVD without getting motion artifacts and other trash. Hour and a half? More? Less?
Jeff Bellune
Re: Maximum movie length for good quality
on Mar 21, 2009 at 6:52:34 pm
90 minutes give or take a few. It depends on the footage. High-motion footage or footage with a lot of detail like forests and water surfaces will need higher bit rates which will limit the time available. You could get up to 2 hours for stuff like talking heads.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Rex Summerfield
on Mar 21, 2009 at 8:37:51 pm
Thanks Jeff, Do you find that Encore does a good job with auto compression for movies pushing the 90 minute mark or do you figure the bit rate and set it manually?
Jeff Bellune
on Mar 21, 2009 at 8:46:31 pm
I've been happy with Encore's performance when Automatic Transcoding is used for projects 90 minutes or less.
-Jeff
