Menu problem related to first play
COW Forums : Adobe Encore DVD
Edwin van Eijk
on Mar 8, 2009 at 10:45:36 pm
I' am using Encore CS4. And I have problems with running the DVD on a DVD-player if I include a menu in the project. I have about the same problem on two different players. If I use windvd it's working alittlebit better.
* menu as first play.
Problems on both player including windvd
Doesn't start
* Short blackvideo as a firstplay -> Menu
Problems on both players except windvd (windvd is working better)
Runs video and hangs
* Sequence of timelines without Menu
Working fine on all players including windvd
runs all video's
Could someone help me out? Does anyone have an idea?
Thanks Edwin
Jon Geddes
Re: Menu problem related to first play
on Mar 9, 2009 at 5:46:43 pm
How long is the black video (maybe its too short?) and you are sure it's end action is set to go to the menu?
I had a problem in a project recently where I forgot to link my first play intro video to the main menu before I built the image. After I realized my mistake, I went back and fixed the end action. After doing so it previewed fine, however, after building the image, it still didn't follow the end action! I tried over and over again, deleting the end action, then linking it back up, all previewing fine, but once it built the disc/image... it was still retaining the original settings of not having an end action. The only way I could solve the problem was deleting the menu and asset from the project, reimporting them, and then setting the end action. Also make sure you don't have your first play set to loop (if its a menu).
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com
Edwin van Eijk
on Mar 9, 2009 at 7:48:06 pm
Jon,
Thanks for your advice. I tried every step but it didn't help.
1) My blackvideo was a little short but I extended it from 1 second to 10 seconds.
2) I think I had the same expieriance with the import of the files. I did have some problems with linked files as well and after a new import it was gone.
Currently my way of working is
1) import to sequences using adobe dynamic link
2) create the 2 timelines
3) Create a simple menu from one of the templates
4) link the diskicon to the " black video" sequence
5) Link the latter one to the menu
6) link a menu option to the second sequense
7) link the end action of the second video to the menu
8) Build de project to a folder
9) for testpurposes I burn the folder to an dvd-RW uisin magiciso
10) play it on a portable DVD-player
Result: I see the blackvideo and the screen stays black
If I do the same thing without the menu its working fine
I am a littlebit frustrated becausde I like Encore together with premiere and photoshop. It's super. But this menu thing is a real pain.
Any help would be great.
Regards
Edwin
Jon Geddes
on Mar 9, 2009 at 10:56:20 pm
Do this:
1) Create a new menu using the blank menu template (in the general category)
2) Add your black video to that menu as a video background (under the motion properties)
3) In the properties for the menu, set loop to none
4) Make sure the menu is set to first play (right click on menu in project window, set first play)
5) Create a new menu from the template you liked
6) Link the end action of the first menu to the one you just created
7) Add your timeline(s) for the main video(s)
8) Link the buttons on the main menu to the timeline(s)
9) Build
Let me know how that works
Jon Geddes
Edwin van Eijk
on Mar 10, 2009 at 8:45:53 am
Well I think I fixed it and made the following changes to the process:
8) Build de project directly to disk using 2.4X speed instead of to a folder
9) Do not use magig iso
Maybe it works wit a DVD folder aswell (didn't test it yet). I think it relates to the Burning speed . Everthing is working fine even without the blackvideo as a first play.
Jon thanks again for your advise and help.
Regards
Edwin
