EncoreCS3 Subtitling problems
COW Forums : Adobe Encore DVD
Kevin Gilmour
on Feb 24, 2009 at 4:17:49 pm
Hi everyone,
I'm creating a DVD project in Encore CS3, it is a revision of a previous project so I simply reconnected the media and made the subtitling alts by hand in Encore. The subtitles were originally imported from a text file.
When I burn the disc however the old text is still in place. The timings have been changed, but not the text. Weird.
Anyone have any ideas?
I was thinking there may be a cache or something but I can't find it.
Cheers
Kev G
Jeff Bellune
Re: EncoreCS3 Subtitling problems
on Feb 24, 2009 at 5:03:44 pm
1. Select all your subtitles
2. Adjust the kerning
3. Undo
4. Build
That should fix it. Test on an RW disc so you don't get any coasters.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Kevin Gilmour
on Feb 25, 2009 at 1:35:02 pm
Thanks Jeff, this sort of worked!
When I changed the kerning and burned a disc it didn't work. So I went back and burned an Image, sent it to another machine, burned it there and it worked!
For some reason if you burn the disc directly from Encore (or create a DVD Folder) it doesn't pick up the changes but if you export an Image file, it does.
Weirdest problem ever.
Kev G
