Motion Menu wmv file short
COW Forums : Adobe Encore DVD
nitzan assaf
on Feb 11, 2009 at 9:35:18 pm
hii,
i have encore cs4 and when i add motion menu add render its works fine..but when i adding an audio file with the motion menu wmv file the original from the library after rendring with the video and audio and playback the menu ,after the original lengh of the wmv file its go to black video!!! who i can loop the motion menu to continue till the end of the audio!!
Joe Bowden
Re: Motion Menu wmv file short
on Feb 11, 2009 at 10:13:23 pm
Your audio is longer than your video in your motion menu?
If you don't want it to go to black, they must have the same duration. Loop it in your NLE so that the duration of both match.
nitzan assaf
on Feb 14, 2009 at 7:31:26 pm
hii,
what is NLE? what do you mean?
there is no other way to change in encore for looping the video motion to the duration of the audio??
tahnks
nitzan assaf
on Feb 14, 2009 at 7:34:34 pm
i edit in premiere cs4 the video for the specific duration of the audio and export in media encoder to wmv file.
i import in encore and try to use as motion menu with the audio and render and now its all black!!
what to do?
nitzan assaf
on Feb 17, 2009 at 9:05:38 am
can enyone help me with my problem?? who i edit the file that will work fine in encore and there is no other way to change the duration of the video that will fit to the audio without extrenal software by editing..and if so...who i export my video from premiere cs4 that encore will recongnize?..
thanks..
Joe Bowden
on Feb 17, 2009 at 2:39:37 pm
Make your video and audio assets the same duration before importing into Encore.
This must be done in Premiere, After Effects, or the NLE of your choice.
nitzan assaf
on Feb 17, 2009 at 3:45:25 pm
i did it in premiere and when i import to encore and link to menu and render, its black all the time!!
what to do?
i export as wmv file PAL..
someone know??
Joe Bowden
on Feb 17, 2009 at 4:18:12 pm
Try another video format, such as AVI.
