test Blu Ray iso
COW Forums : Adobe Encore DVD
Ryan Aquino
test Blu Ray iso
on Feb 10, 2009 at 4:27:12 pm
I have Encore CS4.
I created a 10 GB iso file from my project, and I need to mount and test the iso before I burn the disc.
I'm using Daemon Tools to mount the iso, but can't get anything to play it. Also when I look at the disc in windows explorer, it says it's corrupt and can't read the disc.
But when I run Roxio's drive info, it does see the virtual disc, as a blu ray 10 GB.
Anybody know how I can test an iso disc??
Additional Info:
--I don't have a blu ray burner in the computer, it's installed in the automated duplicator.
--Running windows XP.
Joe Bowden
Re: test Blu Ray iso
on Feb 10, 2009 at 6:49:22 pm
Windows XP doesn't recognize the file formatting on Blu-ray discs.
As far as I know, there are no software Blu-ray players that will read BDMV folder that is not written to a Blu-ray disc. Blu-ray licensing is very, very strict.
There may be freeware that can do it. Check videohelp.com for any tools.
Jon Geddes
on Feb 10, 2009 at 8:00:57 pm
Make sure you have the latest version of Daemon Tools. Also, it could be your software player. Like Joe said, XP doesn't recognize Blu-ray disc format, so trying to view the contents in windows explorer/ My Computer will give you an error.
I use Power DVD 8, which supports mounted blu-ray images. I believe older versions are not able to play images. As long as your software is up to date and capable of playing Blu-ray, you should have no problems. Your monitor also has to support blu-ray (HDCP compliant).
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com
Ryan Aquino
on Feb 10, 2009 at 8:12:26 pm
I think I've got this figured out but the trial version for PowerDVD8 doesn't support Blu-ray playback.
Is there any trial/freeware that will allow me to test an iso for playback??
Joe Bowden
on Feb 10, 2009 at 8:26:26 pm
[Jon Geddes] "I use Power DVD 8, which supports mounted blu-ray images."
That is good to know...thanks, Jon!
Yiannis Valkan
on Feb 17, 2009 at 3:03:02 pm
You can try Power DVD version 7.2.
Thats the ONLY version that support playback of BDMV folder.
Next versions removed that option for the reason Joe mentioned.
2 minds are better than one.
