Encore CS4 keeps quitting while building BD disc - "You have inserted a blank BD"
COW Forums : Adobe Encore DVD
eli tishberg
on Feb 8, 2009 at 4:07:27 pm
Hi all,
"You inserted a Blank BD"
I am working in Encore CS4, and this message keeps popping up.
Each time, I select ignore after checking the box that says "make this the default action".
Then it pops up while I am trying to build the disk.
Unfortunately Encore (CS4) keeps crashing before it can complete the disk and I am wondering if this is the culprit.
When I select a Blu-ray disk from the build menu or when I begin the build the requestor keeps popping up.
Then while it is building the disk it eventually pops up and then crashes, which is why I suspect this may be the culprit.
eli
Clint Milner
Re: Encore CS4 keeps quitting while building BD disc - "You have inserted a blank BD"
on Feb 10, 2009 at 10:42:28 am
CS3 was crashing on me everytime I selected Blu-Ray from the Format drop-down box where you choose DVD, Blu-Ray or Flash.
I found out that it was my Blu-Ray player causing this. I believe it was a Pioneer BDR-101a. What is your drive?
I've since upgraded to a Pioneer BDR-202 and the error is gone and I've been able to burn Blu-Ray discs in CS3 and now in CS4.
Although I choose to burn an BD-R image and then burn the image using IMG Burn.
Hope this helps.
Clint
