Fatal Error Code 6
COW Forums : Adobe Encore DVD
Joe Bandy
Fatal Error Code 6
on Jan 17, 2009 at 8:13:03 am
I have been trying to build a Blu-Ray disc in Encore CS3 and have been receiving an error that states:
Fatal Error Code 6
I think this is referring to a region code but encore doesn’t allow you to specify any regions for B-Ray anyway.
Does anyone know what this means?
John Rich
Re: Fatal Error Code 6
on Jan 17, 2009 at 2:29:36 pm
http://www.adobeforums.com/webx?128@@.59b542e6
JOHNR
Joe Bandy
on Jan 21, 2009 at 5:14:29 am
I tried installing the patch onto one of our two editing systems and ran a small test which worked!
I'm going to try to make a Blu-Ray tomorrow. I'll let you know what happens.
Wesley Cardone
on Aug 13, 2009 at 11:02:15 pm
I see this from time to time and it is nerve wracking. Here is one thing I have found that sometimes solves the problem.
Look or search recursively in the project directory for any *.log file. Look in that file with Wordpad so that it doesn't look like a hash of text like Notepad would show. Scroll down to the bottom and look for an error message about an orphaned file, usually a menu. In the project edit that menu in Photoshop simply saving it as a Photoshop file to some different name outside of the project. In Encore delete that menu. Quit Encore saving your work. Restart Encore and add that Photoshop file as a menu from the external location. Reattach whatever it had and run with it.
More than likely if there was an orphaned file this will fix the problem.
Daniel Gonzalez
Re: Fatal error code 6
on Jan 16, 2010 at 3:12:59 pm
To me when I appeared to a playlist of chapters and included a chapter of a brand-timeline without final action (which in my case was the first, That did not correspond with any chapter, But with the beginning of my movie)
Adding to that first makes a final action and did not give me error, I hope this helps someone who is like me, Peleandose with this hateful and wrong program.
Which would give a DVD Studio Pro with authorship of blue ray...
