using a three hour avi (please help)
COW Forums : Adobe Encore DVD
Maurice Jaffray
on Jan 10, 2009 at 8:55:29 pm
I've been asked to create a dvd with menu that will play in domosteic DVD players. I'll have access to encore which I've used before but my problem is that the avi file to be used is just over three hours long.
What would be the best way to setup this DVD? I understand 3 hours is rediculously long and it probably needs compressing somehow but due to the size and time transcoding, I don't have many attempts of experimentation.
Any help would be greatly appreciated
Jon Geddes
Re: using a three hour avi (please help)
on Jan 12, 2009 at 4:30:07 am
Have you used a bitrate calculator yet? If not, this is the one I occasionally use:
http://www.videohelp.com/calc.htm
You will have to put it on a dual layer disc (DVD9). I recommend Verbatim 2.4x. As for the bitrate calculator, I recommend going just under what it says you can encode it at. So if it says 5976 kbits/s, I would do it at 5800 kbits/s (5.8 mbits/s)
Jon Geddes
Motion Graphics Designer
http://www.precomposed.com
