BD-Rs only in 1280x720???
COW Forums : Adobe Encore DVD
Peter Parker
on Nov 23, 2008 at 6:58:21 pm
Oh hai :)
first sorry for my bad english :)
Well i have an encoding problem. I wanna create a BD-R from some rendered 1080p footage (25fps). Everytime i import the renderd quicktime (animationcodec) as an asset in encore it makes a timeline in 720p no matter if i choose 25p oder 50i for the transcode settings - really wired 8-o
So i thought to leave encore and doing the encoding in premiere but the result is always the same. i'm getting a 720p file :-(
Next i did the encoding in TMPG and Quicktime - both are working fine but the Output (m2t and mv4) can't be importet in encore without transcoding AGAIN! NOW THIS is totaly strange - because i thought Bluray is h.264 OR Mpeg-2. Hmmm.... to you guys have any tips for me?
Thanks!!!
Jeff Bellune
Re: BD-Rs only in 1280x720???
on Nov 24, 2008 at 12:40:06 am
If I'm not mistaken, 1080p/25 isn't part of the Blu-ray spec. It's not a legal BRD file.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Lucas Fazzary
on Nov 26, 2008 at 6:19:57 pm
Here are the options for BD
BD Video Type Frame Rate Codec Available
Frame Size 1920 x 1080 16:9 Ratio
HD 1080 24p 23.976 progressive MPEG-2, AVC, VC-1
HD 1080 60i 29.97 interlaced MPEG-2, AVC, VC-1
HD 1080 50i 25 interlaced MPEG-2, AVC, VC-1
Frame Size 1440 x 1080 16:9 Ratio
HD 1080 24p 23.976 progressive AVC, VC-1
HD 1080 60i 29.97 interlaced AVC, VC-1
HD 1080 50i 25 interlaced AVC, VC-1
Frame Size 1280 x 720 16:9 Ratio
HD 720 24p 24 progressive MPEG-2, AVC, VC-1
HD 720 60p 59.94 progressive MPEG-2, AVC, VC-1
HD 720 50p 50 progressive MPEG-2, AVC, VC-1
Frame Size 720 x 480 16:9 Ratio or 4:3 Ratio
SD 480 60i 29.97 interlaced MPEG-2, AVC, VC-1
Frame Size 720 x 576 16:9 Ratio or 4:3 Ratio
SD 576 50i 25 interlaced MPEG-2, AVC, VC-1
