Custom Highlight button problems
COW Forums : Adobe Encore DVD
Chris Traeger
on Nov 11, 2008 at 4:26:17 am
Hello, I've been staring at this for quite some time now. I have buttons that I want to overlay. The active button itself will be separated from the next...but the highlight overlays the last. Here is an example for you.
http://img134.imageshack.us/my.php?image=photoqe6.jpg
http://img134.imageshack.us/my.php?image=webkc1.jpg
As you can see what I'm trying to do. I only want "Photo" and "Web" to be the buttons and the pictures to be the highlights. Is there anyways of doing this without blowing up the intertoobs?
Chris
Joe Bowden
Re: Custom Highlight button problems
on Nov 11, 2008 at 6:28:19 am
The only way to do this is to use two menus - in DVD-Video (the rules of which govern nearly all Encore behavior), buttons cannot overlap and can only use subpicture highlights.
Make two menus that look as you want, and set the buttons to auto-activate and link to the next menu, except for the buttons that actually link to the content (on the second menu for each button).
Chris Traeger
on Nov 11, 2008 at 6:41:32 am
So in that case I can actually use video transitions to the next menu? What is the auto activate function, rather than select?
Joe Bowden
on Nov 11, 2008 at 3:58:59 pm
If you want, yes you can have video transitions to the next menu.
Auto-activate means to press when the button is selected.
