Closed Captioning Help
COW Forums : Adobe Encore DVD
Larry Zapotocky
on Nov 8, 2008 at 3:55:41 am
I have received my .scc files back from a professional captioning company and I import them into Encore CS3 to the video timeline with no errors. When I burn the DVD, I can't see the CC on any TV.
I've played them on different DVD players and different TV's but nothing.
I don't know if it matters, but the CC is in Spanish.
I'm on a very tight deadline. If anyone can help please let me know.
Thank you in advance.
Larry
Joe Bowden
Re: Closed Captioning Help
on Nov 8, 2008 at 4:40:55 pm
Have you tried embedding the CC on a different field?
Larry Zapotocky
on Nov 8, 2008 at 7:15:46 pm
It only gives me one option: Field 1.
I can't find anywhere else to choose another field.
The .scc files have colons in the timecode (00:00:00:00)and the Encore timeline has semicolons in the time code (00;00;00;00). I changed the .scc original file to semicolons and it still didn't work.
I did notice that the .scc file starts @ 00:00:02:09, but my timecode in Encore starts @ 00;00;00;00. Could that be the problem?
If so, any thoughts?
Thanks again,
Larry
Joe Bowden
on Nov 8, 2008 at 10:07:29 pm
Hmm, you're right...CS3 doesn't offer Field 2. Encore 2.0 does offer both fields for closed captioning.
Closed captions being in Spanish wouldn't cause this problem. But the CC timecode beginning at 2:09 might, and the fact that it has colons instead of semi-colons separating hr/min/sec/frame may also be at issue.
Have you tried replacing timecode colons with semi-colons in the original scc file? Once you've done that, also try subtracting 2;09 from all timecodes, and see if that helps.
Larry Zapotocky
on Nov 9, 2008 at 3:21:00 pm
I've replaced all the colons with semicolons, but I have not tried subtracting 2;09 from all the timecodes.
I will let you know.
Larry
