stuck on progress bar - re-rendering?
COW Forums : Adobe Encore DVD
Tom Kays
on Nov 6, 2008 at 7:53:12 pm
I am new to Adobe Encore (am very familiar with Elements and Pro) and have finished creating my first DVD with encore. When I try to render the project, the menu, or even just go straight to build DVD, the progress bar gets to the end of rendering the first menu (of 5) and then jumps back to 299 frames - jumps forward to 399 and then appears to re-render from there, repeatedly. I have not gotten past this point after several tries. I have saved it as a different file but same issue. I am at a loss.
The finished DVD is 80 minutes long, has an intro movie before the main menu shows up, 5 sub-menus. None of these menus are moving - all of them are still backgrounds from the library..no audio on them either - just very basic. Any help is appreciated!
Thank you!
Jeff Bellune
Re: stuck on progress bar - re-rendering?
on Nov 6, 2008 at 9:31:43 pm
Maybe this Encore FAQ entry in the Adobe Encore forum will help.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Tom Kays
on Nov 7, 2008 at 2:07:03 am
Thank you! That first option was my issue and the disc burned just fine! YAY!!!!
