AVI files corrupt???
COW Forums : Adobe Encore DVD
George Cox
on Oct 18, 2008 at 5:21:20 pm
Following problems with my computer [XP] I have had to reinstall EncoreDVD version 1. Every time I try to import an .avi file as an asset I get the following message. Could not import the file. May be corrupt or the type may not bee supported.
I have tried to import numerous files that I have used before with the same result
I have tried reinstalling the programme and it is still the same.
Any help that you can give me would be appreciated.
Also. will Encore V1 run on a Vista machine?
Thank you,
GEORGE.
Joe Bowden
Re: AVI files corrupt???
on Oct 19, 2008 at 12:46:04 am
Sounds like you may be missing a codec.
Encore version 1 was released in 2003, several years before Vista. Last I knew, Encore 1.0 only supported Windows XP.
George Cox
on Oct 19, 2008 at 12:53:30 am
I managed to find my V2 and have installed that so problem solved.
Richard Talmage
on Oct 22, 2008 at 8:05:38 pm
I have the same problem. I am picking up the same response from an avi file that encore says it is corrupt. Any idea what is going on with this clip?
Richard Talmage
Cape Cod, MA
George Cox
on Oct 22, 2008 at 9:08:14 pm
Richard,
I never cured it. I was lucky that I found my Version 2 disc and was able to reinstall it so I did not pursue it.
