Footage Letterboxed??????
COW Forums : Adobe Encore DVD
David Barry
on Sep 30, 2008 at 12:16:06 am
I am trying to author my first blu-ray disc... and I am having a very strange issue.
The footage is DVCPRO HD, shot on an HVX200, edited in FINAL CUT PRO in its DVCPRO native environment 1080, 24 fps. I then exported the footage as self contained Quicktime movies from FCP.
When I bring them into my Encore project, they are playing smaller than the preview frame, letterboxed, with the wrong aspect ration.
I also created a motion menu for the project, using the same footage and now that it is rendered it is playing back full 16x9 frame perfectly. I dont know why the timeline tracks are not working properly.
Any suggestions???
Jeff Bellune
Re: Footage Letterboxed??????
on Sep 30, 2008 at 12:23:09 am
Did you check File>Interpret Footage and verify that Encore is seeing the file as 16:9? I think for full-frame HD it is 1920x1080 with a PAR of 1.0.
The Focal Easy Guide to Adobe Encore DVD 2.0
David Barry
on Sep 30, 2008 at 12:36:46 am
The Interpret footage options I get are as follows:
Uste the assets Pixel aspect ration: SD NTSC Widescreen (1.2)
Or I can choose to conform it to one of the following:
Square Pixels (1.0)
SD NTSC
SD NTSC Widescreen
HD Anamorphic
I dont get any options that are 16x9
Jeff Bellune
on Sep 30, 2008 at 12:43:30 am
[David Barry] "Use the assets Pixel aspect ratio: SD NTSC Widescreen (1.2)"
That is the wrong interpretation.
Try setting the PAR to square pixels and let us know what happens.
-Jeff
David Barry
on Sep 30, 2008 at 12:49:00 am
When I change it to square it changes the timeline aspect ration to 4:3, and the choices are grayed out so I cannot adjust it.
When I look at the timeline in preview it has black borders all the way around the video, like it is not filling the screen, though the aspect ratio appears correct. It looks like what happens when you take a standard def 16x9 image and drop it into a high def 16x9 frame.
Jeff Bellune
on Sep 30, 2008 at 12:54:00 am
Odd. I recommend trying "HD Anamorphic", just to see what happens. Be alert for image distortions.
If that works, then you have your answer. If not, I would re-check then double-check your export settings from FCP.
-Jeff
Mike Cohen
on Oct 2, 2008 at 1:31:18 am
As an experiment, export a short clip as MPEG-2 or H264 BluRay, whatever format you are using, and see how Encore interprets that file.
