encore on mac giving a windows error????
COW Forums : Adobe Encore DVD
Twann Hudson
on Sep 22, 2008 at 9:53:39 pm
i have created a project on a mac 4 core a few weeks ago using encore i sent it out using the flash option - now two weeks later I'm trying to make another flash file . i have not changed anything nor moved and files around - but it's giving me the error that -
this project was created on a windows platform and can not be opened on the mac!
what can cause this ?
the real fun begins when the program loads
running FCS & CS3 MS side by side on the Mac
Ben Holmes
Re: encore on mac giving a windows error????
on Sep 27, 2008 at 11:13:02 pm
Bad software. Have a search below for the same issue. It's just buggy, awful software. Sorry about that.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
Jordi J Recort
on Nov 11, 2008 at 1:15:13 pm
I found a solution..
as stupid as the problem is!!!!
Maybe will not be suitable for everyone, but it works if you have both computers on the same network.
1. copy all the assets to the second mac (as you will do anyway)
2. From Mac 2, connect to Mac 1 and remotely open the project from Mac 1
3. The project will open on Mac 2 and will ask to reconnect media
4. Reconnect media to the local folder on Mac 2
5. Save as the project on local hard disck on Mac 2 and you're ready to rock!
Stupid workarounds for stupid problems!
Jordi J. Recort
Jordi J. Recort
Composer & Editor
Matthew Harnick
A solution to "This project was created on the Windows Platform" error
on Dec 29, 2009 at 9:42:21 pm
I can't say this will be the issue each time, but I've been getting this issue for ages, and somehow it finally dawned on me what happened, in this scenario at least.
I was consolidating a couple of project folders into a larger one, and moved the .ncor file as well. I had just been working with this project, and had just saved it right before I moved the .ncor file, so I knew it was something simple. All I did was move the .ncor file back to where it was previously located, and it worked fine.
Again - I'm not suggesting that this is the only reason this error would occur, but in my case it was a two-second fix and the right fix. Moral of the story, don't move anything until it's done. Good luck.
© 2018 All Rights Reserved
