Menu's Off Using Different Burner
COW Forums : Adobe Encore DVD
Jeff Manghera
on Jul 15, 2008 at 4:24:30 pm
I recently made a DVD with Encore and burned the finished product to a disc using the same computer I created the project on (I actually created the DVD files and made the disc from that). The DVD worked exactly as it was suppose to. I burned another DVD from the same files (off of a portable hard drive) using a different computer and the menus/highlights were off. I went back and was able to burn a perfect DVD on the original computer using the exact same files. Anyone ever see this problem before? Does anyone know why this happened?
Joe Bowden
Re: Menu's Off Using Different Burner
on Jul 15, 2008 at 7:00:16 pm
Try this - on the computer that does not show this problem, build a DVD image. Then burn from the DVD image on the other computer.
Here's a thought: were your button highlights text? Maybe your other computer doesn't have the font used in the menu?
Jeff Manghera
on Jul 15, 2008 at 7:09:19 pm
The DVD files I used were the .VOB/.IFO files I created through Encore. I probably should have been clearer in the first post. I'll try the image file idea. Thanks.
