How to change subtitle aspect ratio from 16:9 to 4:3?
COW Forums : Adobe Encore DVD
Kriss Rozins
on Jun 27, 2008 at 12:52:33 am
Hi!
A little problem I can't solve...
There's a DVD project consisting of many subtitled timelines (subtitles are done in Encore, not imported as images etc).
In the beginning whole project was ment to be in 16:9 aspect ratio, so I did all the subtitling in timelines set as 16:9.
Now some timelines must be changed to 4:3 and this is where the problems start...
When I change timeline aspect ratio to 4:3, subtitle text presses along (letters look stretched vertically). I need them to look normally (not pressed from sides).
I tried different fonts and font appearing styles but nothing helps.
Are there any tricks for solving this?
P.S. I use Encore DVD 2.0
Joe Bowden
Re: How to change subtitle aspect ratio from 16:9 to 4:3?
on Jun 27, 2008 at 2:33:49 pm
That is a tough one...
Have you tried selecting all the subtitle clips, then changing the font in the Subtitle properties? And then change back, if you like.
Does that fix it?
Kriss Rozins
on Jun 27, 2008 at 11:30:51 pm
Nope - letters still stay stretched...
