Chapter Links from Photoshop
COW Forums : Adobe Encore DVD
Byron Nash
on Jun 26, 2008 at 7:09:18 pm
After reading the manual I'm led to believe that using the (+#) tag on a Photoshop Layer I can automatically link to a specific Chapter in a timeline. For example it seems like the layer set "(+#)Chapter 1" should generate a link to Chapter 1 in the timeline. I could have sworn that I got it to work once but I have not been able to do it again.
Byron Nash
3D Artist
http://www.editatjoes.com
Joe Bowden
Re: Chapter Links from Photoshop
on Jun 26, 2008 at 7:48:25 pm
That's only half of it (and you don't need to do this work in Photoshop) - you need to select the "Create Chapter Index" command.
Do a search of the help for "chapter index" and everything you need to do this will be revealed.
Byron Nash
on Jun 26, 2008 at 7:51:25 pm
I did see that part about Chapter Indexing. I was hoping to script the menu creation in Photoshop or After Effects, I guess the Chapter Index feature is good enough. So you're saying that what I was asking isn't possible?
Byron Nash
3D Artist
Joe Bowden
on Jun 27, 2008 at 3:59:32 pm
No, there's no way to build a menu in Photoshop that automatically links buttons to a timeline.
The Chapter Index feature is what you read about, and it is possible to add the prefixes in Photoshop - but that won't link the buttons for you (you must select the "Create Chapter Index" command).
