"End of File" Error!
COW Forums : Adobe Encore DVD
Gary Angle
on Jun 17, 2008 at 9:53:35 pm
I’m having trouble writing the DVD to a disk or a folder!
It will build up to the same halfway point and throws up ‘End of File’!
The entire Build is only about 2GBs.
I did a check project and it’s clean of errors. Before the Build, I found several orphan timelines, which I deleted. I also found a button that was placed, but not necessary.
What can the problem be, if I’ve come this far and get a clean Check Project?
I don't know where to start looking for a problem in the Building process! Nothing points at a problem!
Thanks for any help,
Rob Paludanus
Re: "End of File" Error!
on Aug 11, 2008 at 6:45:54 pm
Same problem here, with a duallayer project after writing 6.9 Gb out of the 7.87 needed i get this error.
Who knows what to look for/repair if i check the project it gives no errors and/or broken links.
© 2018 All Rights Reserved
