End of stream has been reached Error message
COW Forums : Adobe Encore DVD
Mohamed ALAMI
on May 26, 2008 at 7:33:39 am
I'm using Encore CS3, my project containing video clips and slide show's, while building the project and after an hour, i received this Error message " End of stream has been reached"....
what does it mean, where i have wrong?
many thanks
Mohamed
Moe
Richie Finch
Re: End of stream has been reached Error message
on Jul 5, 2011 at 12:14:27 pm
I have the same problem Moe !
did You sort it ???
Rich
Steve Hix
on Apr 27, 2012 at 12:46:46 pm
I had a working project (2 timelines, 2 menus, 1 slide show). I rearranged the order of some slides, then got a "Stream Overlay" error.
I unchecked 'Fit slideshow to audio duration' then rechecked it to recalculate the duration (I guess... that fixed a different problem earlier). Now I'm getting "End of stream has been reached". All due to changing order of slides in a slide show, I also resized one slide, the same way I have earlier with no problems.
Does this help with a possible solution?
