Check Project???/ Button Hierearchy????
COW Forums : Adobe Encore DVD
Joey Condeelis
on Apr 24, 2008 at 11:54:52 am
I am ready to burn a DVD and when I check Project I get this "Untitled Project" and then "Title Remote not set" What is it and how do I set it or fix it. DVD renders just fine anyway, just wanting to learn. THANKS
ps I know how to "Rout Buttons" but I do NOT know how to rout or CHANGE the middle number on the routing display. How do I make or change the buttons Hierarchy?????
THANKS!!!!!!!!!!!!!!
THANKS
Jeff Bellune
Re: Check Project???/ Button Hierearchy????
on Apr 24, 2008 at 12:53:19 pm
Title Remote is set in the Properties panel for the Disc. It determines which menu gets activated when the Top Menu or Title Menu button is pressed on a DVD player's remote control.
Each menu button has a properties sheet in the Properties panel. Button number one is the default button. The default button is the one that is highlighted when the menu appears. Use the Properties panel to change button numbers.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Joey Condeelis
on Apr 24, 2008 at 4:05:56 pm
THANKS Jeff!
THANKS
Jeff Bellune
on Apr 24, 2008 at 4:20:39 pm
You're welcome. :-)
