Menu problem
COW Forums : Adobe Encore DVD
Joseph McDonald
Menu problem
on Apr 21, 2008 at 7:56:27 pm
So I created a menu in photoshop and the deminsions of the background layer I used is 720 x 480. When I import the menu and look at it in the viewer in encore it appears to have a mask at the top and bottom of the menu (black bars) No when I drag in a stock adobe menu in the same project, it goes away. Does anyone have any ideas as to what is going on?
Jeff Bellune
Re: Menu problem
on Apr 21, 2008 at 9:36:31 pm
What pixel aspect ratio did you use in Photoshop?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Joseph McDonald
Re: Menu problem
on Apr 21, 2008 at 9:53:13 pm
I will have to check when I get home. What should it be?
Jeff Bellune
Re: Menu problem
on Apr 21, 2008 at 9:55:44 pm
It depends on your project. 4:3 NTSC DVDs use 0.9 and 16:9 NTSC DVDs use 1.2
-Jeff
