Video Transition Discrepancy
COW Forums : Adobe Encore DVD
Justin Skotarczyk
on Apr 11, 2008 at 12:26:02 am
I am trying to make an apparently seamless transition from menu to menu, but having issues with the video transition appearing larger than the interactive menu.
The menu is a .psd file 720x480 and the video is a .mov with the same dimensions.
The effect I am going for is when you click the button it animates, shifting to a different position by the next menu screen. Every aspect of the background should stay the same otherwise.
Even upon burning a DVD, there is a jarring increase in frame dimension when the transition occurs.
Any suggestions?
Justin Skotarczyk
Re: Video Transition Discrepancy
on Apr 13, 2008 at 12:32:44 am
I figured out the issue. Encore tends to squish menus down to 720x480 regardless of the fact that it'll accept 720x486 and 720x540 compositions as menus.
We ran a few tests to confirm this, and ended up rebuilding our menus in Photoshop using a 720x480 template, and used that file to reanimate in After Effects. After doing this we were able to get near seamless video transitions in Encore.
Justin Skotarczyk
DI Film
justins@milagropost.com
Milagro Post
Detroit, MI
Freelance VFX Artist
skoproduction@yahoo.com
