encore transcode settings
COW Forums : Adobe Encore DVD
Arthur Klein
on Apr 1, 2008 at 8:40:32 pm
is there a way to let encore transcode from a qt ref file for normal m2v and to turn off the blu-ray transcode?
i dont need blu-ray file.
in audio transcode setting there is a dont transcode choice. I dont see it on the properties menu transcode pulldown menus. How do i only have it trancscode dvd?
Jeff Bellune
Re: encore transcode settings
on Apr 1, 2008 at 9:41:46 pm
What is the frame size of your qt ref file?
The Focal Easy Guide to Adobe Encore DVD 2.0
Arthur Klein
on Apr 2, 2008 at 12:07:13 am
hi Jeff,
Thanks for your response.
i am using Encore DVD CS3 and the frame size through a QT Ref Avid DNX 220 encoded 1080x1920i 29.97. Encore reads Ref file fine other than i need to crop 6lines top and 6 lines bottom to get rid of Black on rt and lf frame (probably the difference of 720x486 / 720/480).
How do i turn off the blu-ray encodeding? I only need the mpeg2 for standard def ntsc dvd.
Jeff Bellune
on Apr 2, 2008 at 1:33:27 am
Resize your video in Avid to 720x480 before exporting. The frame size you are using will always be interpreted by Encore as Blu-Ray.
-Jeff
