External burner but Encore writes to internal drive?
COW Forums : Adobe Encore DVD
Tim Taylor
on Mar 16, 2008 at 8:36:32 pm
I am trying to get Encore to write to my external DVD writer, but every time I export directly to disc from Premiere Pro CS3 (i.e. I don't want to author menus) Encore insists on using my internal drive!
I've read about changing the cable order of drives, but this is a laptop with an external drive so changing cable order is not possible.
Can anyone offer suggestions what I might do next?
Are Adobe aware of this bug, as it is a bug when you can't select which drive you want to burn to!
Or am I missing something in the set up?
Jeff Bellune
Re: External burner but Encore writes to internal drive?
on Mar 16, 2008 at 9:39:41 pm
Cancel the build once you are in Encore, then go to the Build tab and change which drive to burn to. Then build/burn again.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Tim Taylor
on Mar 28, 2008 at 7:11:33 pm
Thanks....
I've set the external drives drive letter to one that is alphabetically before the internal one, and now it is seen as default by Encore.
A bad shortcoming by Adobe IMO
