Blu-Ray Burner for Mac?
COW Forums : Adobe Encore DVD
Mark Abney
on Mar 16, 2008 at 2:28:08 am
Can anyone suggest a Blu-Ray burner that is compatible with Encore DVD running on a Mac-G5 Octo-Core? I would prefer an internal drive, but external is fine.... I just want to be sure it is compatible with Encore and/or Toast 8. What are you all using out there?
I am setting up a new system and would appreciate any suggestions.
-mark
Graham Jones
Re: Blu-Ray Burner for Mac?
on Mar 16, 2008 at 6:29:20 pm
check out the drive compatibility database at http://forums.xlr8yourmac.com/drivedb/search.drivedb.lasso -- I would suggest that that LaCie external burner will probably give you the least trouble.
- G.
Mark Abney
on Mar 17, 2008 at 3:54:34 pm
Thanks for the suggestions Graham... I will check out the website.
-mark
Warren Eig
on Mar 17, 2008 at 7:07:53 pm
I'm using a Panasonic SW-5583 internal SATA burner. So far works great.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.atomfilms.com/af/content/knitwits
http://www.atomfilms.com/film/family_xmas.jsp
Mark Abney
on Mar 18, 2008 at 1:43:07 pm
Thanks Warren.
Just wondering.... are you able to burn successfully directly from Encore? or do you save and ISO file and burn with Toast?
I appreciate any noob tips you might have too, as I am crossing over from DVDSP for Blu-Ray projects.
-mark
Warren Eig
on Mar 18, 2008 at 5:05:51 pm
Mark,
I never tried from Encore. I just make a disc image and burn in toast. The advantage to the disc image is I can archive the image and then do multiple burns later.
Warren
Warren Eig
O 310-470-0905
Nick Righton
on Mar 19, 2008 at 2:41:00 am
FYI, Roxio just released Toast 9. It supports Bluray video disc burning now.
I wish I was good at one thing rather than average at many, but oh well.
Dave Jenkins
on Mar 19, 2008 at 5:06:09 am
If you get an internal drive be prepared for a install that takes a bit of time and pulling apart your mac. It's not simple. but doable.
Dajen Productions
Santa Barbara, CA
G5 Quad - AJA Kona LHe
Huge 1.2 Raid
FCP 6.0.2-OS X 10.4.11-QT 7.3
Warren Eig
on Mar 19, 2008 at 5:27:59 am
[Dave Jenkins] "If you get an internal drive be prepared for a install that takes a bit of time and pulling apart your mac. It's not simple. but doable.
Not as hard as you would think. It took about 10 minutes to snake a 24" SATA cable in my octo to the upper DVD drive bays. I didn't have to take out the fan.
Warren
Warren Eig
O 310-470-0905
Mark Abney
on Mar 19, 2008 at 1:48:56 pm
Looks like the optical drive is connected via IDE in my new Octo-Core MacPro.
Are you using a SATA card to run your burner?
I've ordered the FastMac internal IDE tray-loader model and will suffer through the 2x speed for now.
Toast 9 sounds promising too.
So many new toys.
Thanks for all the input!
-mark
Warren Eig
on Mar 19, 2008 at 4:08:11 pm
I hooked up a 24" SATA cable to the two extra SATA connectors on the logic board of my Octo.
The SATA burner can burn a dual layer a 4x.
Warren
Warren Eig
O 310-470-0905
Mark Abney
on Mar 19, 2008 at 11:04:13 pm
Thanks again Warren....
Just contacted FastMac and switched my order to the SATA drive.
4x will help alot.
Plus they sent a handy Pdf explaining the installation!
-mark
Warren Eig
on Mar 20, 2008 at 6:45:59 am
I bought the same one FastMac sells but $100.00 less. It works great. Easy to use. I found FastMac hard to deal with so I took my money else where.
Warren
Warren Eig
O 310-470-0905
Mark Abney
on Mar 20, 2008 at 1:28:05 pm
Wow
I've had a great experience with FastMac so far.
I used their iChat sales support yesterday.... realtime response and very helpful.
-Mark
