Rerouting Buttons
COW Forums : Adobe Encore DVD
Ray Adkins
Rerouting Buttons
on Mar 11, 2008 at 1:51:44 am
I have 6 chapter buttons and a main menu and next button. I can only get to the main menu button from the middle row of chapters (2 & 5 chapters) and I can only get to next from main menu. Is there a way to set up the routing so you can get to main menu and next from any row?
George Wing
Re: Rerouting Buttons
on Mar 11, 2008 at 10:10:45 am
There should be a way to turn off automatic button routing (and manually set the routing). Look in the help under Buttons / Routing.
From memory -- on the right side for the menu properties, there was a checkbox for "Automatic Button Routing" (uncheck that, and then on the menu you can use one of the icons under the menu to show the button routes). This was in Encore 2.0 -- so not sure how much it changed in CS3
Regards,
George
Ray Adkins
on Mar 11, 2008 at 11:52:30 am
Thanks I'll give it a try
