Loop Point Problem
COW Forums : Adobe Encore DVD
Stephen Lubin
Loop Point Problem
on Feb 15, 2008 at 8:59:05 am
I animated the buttons in a menu for the first 5 seconds. I set the loop point to 5 seconds, obviously. However, after a button on the menu is clicked and plays, the menu returns from the start point, showing the first 5 seconds instead of starting at the 5 second mark.
Now, my question is: I know that setting the loop point loops the footage after the duration, but after a video is played should it start at the loop point? Or is what I described normal and beyond my control?
Thanks!!!!
cowcowcowcowcow
Jeff Bellune
Re: Loop Point Problem
on Feb 15, 2008 at 12:47:21 pm
You can't link to a loop point in Encore. The solution is a duplicate menu - one that doesn't contain the 5-second animation.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Stephen Lubin
on Feb 15, 2008 at 7:48:43 pm
Thank you so much!! I understand it now!
