BD Problems
COW Forums : Adobe Encore DVD
BD Problems
on Jan 22, 2008 at 2:29:14 pm
once again... description of my main Problems within encore has disappeared in my last post :-(
I`m working with Encore since Release 1.0
I`m using Envore Version 3.01.008.
Creating a complex DVD, no problems occur.
All the problems become evident in case of making a BD project. I have tested it on several PC`s, different Project Settings ... all with the same problems.
For example:
During the playback of a menü, it is possible to push the pause button (not possible in a DVD project). This has nothing to do with the allowed user actions!!!
In a DVD Project I make use of a Playlist, testing it in a stand alone DVD player you can navigate with the next button from one video to another. The situation in a BD project: Using the preview Funktion in Encore everything is ok. Testing the final BD DVD (PC Softwareplayer or TV stand alone BD Player) the navigation with next button is not possible (only backwards)
DVD Project: motion menü (animation 60 sec, loop point 40 sec)-> in Encore Preview as well as testing the final DVD the motion menü has a length of 60 sec, the highlights become visible after 40 sec, there is no break). The situation in a BD Project: the motion menü seems to be splitted into two parts (40 sec and 20 sec), ad the end of the 40 sec part is a short break. Previewfunction in Encore is OK !!! (one animation for the menü with 60 sec). In case of setting an endaction for this menü AND defining a loop numer of zero (no loops), on the final BD only the fisrt 40 sec part is played, after that the defined end action. Only if you define a loop number > 0 the second 20 sec part will also play. Because of the defined loop the second 20 sec part start with a high audio level. The last statement describes the correct behavior in Encore, but avoiding this I have done the following in a DVD Project: 60 sec motionmenü, highlights become visible after 40 sec (loop point at 40 sec), loop number is null, endaction is the same animation with a audio fade in at the beginning. This workaroaund is not possible in a BD project because of the mentioned BD problems above.
I hope that anybody can give me a feedback
Thanks in advance
the next button function generally don`t work, not only with playlist items. Other controls: scan, previous and so on work properly.
the next function works in all DVD projects... following the DVD specification not in menues but with all items placed in the timelines... but it doesn`t work in BD projects!!
© 2018 All Rights Reserved
