Problem adding audio to menu background
COW Forums : Adobe Encore DVD
Rich Swin
on Jan 21, 2008 at 4:35:35 pm
Hi guys
I've got stumped on something which I hope you could assist with, basically I want to add an audio file to the background of the main menu. Apparenty you need to click on the properties of the menu, then drag the button from the 'audio' section onto the song file in the project window. Problem is, once I click on menu I can't link back the audio to the song in the project window because the menu tab is open. I hope this makes sense and any help would be appreciated.
thanks
Rich
Jeff Bellune
Re: Problem adding audio to menu background
on Jan 22, 2008 at 5:38:17 pm
Once you have the Menu Properties exposed, click on the Project tab of the Project panel to make the audio asset available to the pickwhip.
The Menu properties sheet should still be exposed after you do that.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Rich Swin
on Jan 22, 2008 at 7:14:44 pm
thanks Jeff, that did the trick.
Cheers
