transition failed to work
COW Forums : Adobe Encore DVD
manny
on Jan 21, 2008 at 8:22:52 am
Im using Encore CS3 on Win XP pro machine Quad Core with 2G RAM. I created transitions for each button. The transitions were all exported as Quicktime using Animation codec and 2sec long. However, after burning to DVD, the transition failed to execute. What am i doing wrong? Do I have to export the transition using DV format (like Microsoft DV)? Should it be at least 2 secs long? Thanks in advance.
Jeff Bellune
Re: transition failed to work
on Jan 21, 2008 at 3:22:57 pm
Did the transition execute properly in Encore's preview?
Have you tested the burned disc on more than one player?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
