Disc Quality?
COW Forums : Adobe Encore DVD
Dylan Reeve
Disc Quality?
on Jan 18, 2008 at 12:33:19 am
I've built a DVD and burnt to DVD+R DL for client approval and testing. It generally is fine, but it has been a bit 'skippy' on a couple of bits in some players. The underlying MPEG files are fine, the DVD plays fine in preview, and the error isn't consistent across players, so I'm confident that there's not really anything wrong.
Is this just because the writable discs are a little harder for players to read than commercially replicated ones, or could there be another factor I'm not considering?
How can I go about assuring myself that the problem won't be present in the final pressed discs?
The datarate on the DVD is not an issue, content is between 4.5 and 6Mbit.
Jeff Bellune
Re: Disc Quality?
on Jan 21, 2008 at 3:16:19 pm
Proper burn speed and quality media are your best bets.
Quality: Taiyo Yuden and Verbatim
Burn Speed: No greater than 1/2 of the rated speed of your burner or media, whichever is lower.
The Focal Easy Guide to Adobe Encore DVD 2.0
© 2018 All Rights Reserved
