Are Transitions with Alpha Channels allowed?
COW Forums : Adobe Encore DVD
ejunyor
on Jan 4, 2008 at 7:42:42 pm
Good Afternoon Forum,
There are a few things that I would like to try with Encore, I am making some motion menus in AE, and I was wondering, if I made a transition with an alpha channel could I get it to overlap two menus?
Joe Bowden
Re: Are Transitions with Alpha Channels allowed?
on Jan 4, 2008 at 10:06:52 pm
You have to create your transition material entirely in AE or Premiere, so whatever they support should carry over in Encore.
Eric Jones
on Jan 8, 2008 at 6:30:33 am
Thaks Joe for your response, but I'm not sure I understand would I create the enitre project in Preimere or AE then Import in Encore?
I started building an Encore project from finished clips, and also made a transition as an avi file - is this not going to work?
thanks,
eric
Joe Bowden
on Jan 8, 2008 at 3:44:51 pm
No, not the project - the transition material (i.e., the video that contains a frame grab of the menu, followed by a transition to a clip or another menu, etc) - that transition clip must be made in AE or Premiere.
eric jones
on Jan 8, 2008 at 4:02:35 pm
Thanks Joe,
For a quick response.
Yes I understand now, what you've explained I have done, however my menu is a motion menu...
so I would need that transition to crossover two different clips; alpha channel in use on both clips to make a transition happen as one clips ends (menu still in motion as transition occurs).
That is my dilema, but from your explanation of a using frame grab, it seems as though my wish will not (at this time) be a possibility and I might have to use a work around.
