flowchart
COW Forums : Adobe Encore DVD
d hudson
flowchart
on Jan 3, 2008 at 1:54:39 pm
ok I'm new to this,
In flowchart at the bottom area there are several items that I don't need for the DVD yet I can't get them to go away and it makes my system think the DVD is maxed on space and I don't think it is. how can I get them out?
thanks
Jeff Bellune
Re: flowchart
on Jan 3, 2008 at 2:58:24 pm
Find the items in the Project panel and delete them there. If there are any assets that you want to delete and they are used in project elements like timelines or slideshows or menus, then you will have to delete those before you can delete the assets (or at least you'll have to delete both the element and the asset at the same time).
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
d hudson
Re: flowchart
on Jan 3, 2008 at 3:10:27 pm
Ok I'll try that.
So does this mean anything in the project pannel
assets such as videos and slide shows and such must be used.
I had actually added more things than in the end needed? but I could use to
do a second disc. The project had slide shows and videos and now seems to be to large for the one disc and I just wanted to make a second with the other assests.
dave
