Import as folder bug?
COW Forums : Adobe Encore DVD
Matt Polack
on Dec 21, 2007 at 12:58:27 am
I'm using Encore 2 and am attempting to simply import a folder of photos as an asset: (as I have done numerous times in Premiere)
I am following the steps as described by the help section:
Make sure that the Project panel is active, and do one of the following:
Choose File > Import As > Asset.
Double-click any empty area below the asset list.
Navigate to the file or files that you want to import, select them, and click Open. To import the contents of a folder, select the folder and click Import Folder.
My problem is that when I click on the folder I simply do not see any option anywhere to "Import Folder"...the only option is "Open"
I can only import the files manually into a folder I have first manually created...
Is this a bug in Encore 2? or alternatively What am I missing here? Thanks
Jeff Bellune
Re: Import as folder bug?
on Dec 21, 2007 at 3:45:56 am
This is not possible in Encore CS3, and the CS3 help files do not reference this technique.
I strongly suspect that it's not possible in 2.0, either, and that the 2.0 help files are incorrect.
The Focal Easy Guide to Adobe Encore DVD 2.0
© 2018 All Rights Reserved
