Crash after 20min of "Building"
COW Forums : Adobe Encore DVD
Yen Condeelis
on Dec 8, 2007 at 7:49:30 am
I have Encore CS3 I have one 20 min time line and then 9 slide shows. (Image size is 2816 x 2112 ) I have 1.68GB space left in this project. (about 1/4 left of the blue bar on the Build tap)
My show will burn just fine IF I only have 7 side shows BUT when I add the next two it will build or burn for like 20 minutes and then Encore crashes. I have tryed it 3 times now and it crashes all 3 times. Before I do a build I "Check Project" and ALL is well. Any idea's as to what is going on and HOW I fix it?
Heath Firestone
Re: Crash after 20min of "Building"
on Dec 11, 2007 at 2:41:35 am
Not quite sure, but you might try scaling your slideshow images down to a more manageable resolution in PhotoShop or whatever graphics program you are using. See if that solves your problem.
© 2018 All Rights Reserved
