DVD after burning got very blury
COW Forums : Adobe Encore DVD
Bilaocabecao
on Nov 9, 2007 at 5:26:30 pm
Hello All,
After burning a final DVD disc I noticed it got very blury...any sugestions about exporting to a DVD Disc?
Am I doing something wrong over the compression settings...I haven't change anything in there..I've used the standard settings..Thank you
Cabecao
Jeff Bellune
Re: DVD after burning got very blury
on Nov 9, 2007 at 6:49:50 pm
What version of Encore?
What operating system?
What export settings from what editing program were used?
What file format is the file that was imported into Encore?
What codec is used in the file that was imported into Encore?
How long (in minutes) is the video content that will be used in the DVD?
What are your Encore project settings (DVD, Blu-ray?)
What are your Encore transcode settings?
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Bilaocabecao
on Nov 9, 2007 at 7:45:42 pm
CS3
PC 4 quad - 8GRAM - XP professional
all the footage came from After Effects CS3 | quicktime file | high quality
.mov ( none compression )
none
4 clips each one with 6 minutes long
The footage has an HDV format ( 1440x1080i ) In Encore I'm using Blue-Ray, but when I output to a DVD disc I use DVD settings and not Blue Ray
Automatic | H.264
I'm testing now changing the transcode settigns to Custom and selecting the Mazimum quality ( 1440x1080 ) option.
Jeff Bellune
on Nov 9, 2007 at 8:53:04 pm
I don't know if the answer is this simple, but a Hi Def source will visibly lose resolution and have degraded video quality when re-sized for Standard Def DVD.
Blu-ray at 1440x1080 has more than four times the resolution of SD DVD at 720x480.
Can this resolution difference account for the "blurriness" that you are seeing?
-Jeff
Bilaocabecao
on Nov 9, 2007 at 7:48:34 pm
One more thing I would like to add:
Even in my previews after Rendering the quality is bad (blurry)...Don't know if that matters
Thank you again !
CAbecao
