Exporting from Premiere to Encore CS3 -> timeline too high bitrate
COW Forums : Adobe Encore DVD
Derek Beck
on Nov 2, 2007 at 7:15:02 am
I can't seem to get a good output of my movie from Adobe Premiere Pro CS3 to Encore CS3.
I am using APP's media encoder to export as mpeg2 in elemental (not multiplexed) form, and have tried several CBR at 8 and then 7 Mbps. My audio is PCM. The film is only 23 minutes, so CBR should be fine, based on what I've read. I don't know if it is a factor, but there is the audio track, plus an optional commentary track on the same timeline in Encore, a timeline I call "movie".
However, upon checking the project in Encore, it says "timeline bitrate too high". I notice if I delete the audio from the timeline, the check is fine.
What is the best strategy for best quality?
If you recommend exporting some intermediary format from APP, then using Encore's auto feature, please be specific on what intermediary format I should use. But this is not the ideal choice.
Thanks so much! Desparate to get this project done before I go insane :)
Again, thanks for reading,
Derek
PS: I don't have a license for the dolby audio feature.
PPS: I know APP has a feature to export directly to Encore, but not sure this will work for me because I have elaborate menus and stuff setup in my Encore project already...but if you know of a way, please let me know. :)
Derek Beck
Re: Exporting from Premiere to Encore CS3 -> timeline too high bitrate
on Nov 6, 2007 at 5:24:54 am
Ping?
Joe Bowden
on Nov 6, 2007 at 1:55:26 pm
Please provide details on the audio clips in each audio track (encoding, bit rate, etc.), and also on your project audio settings (you can find this in preferences).
Derek Beck
on Nov 6, 2007 at 3:49:03 pm
Thanks for the reply.
For the two audio files on the "movie" timeline, the one I'm trying to export to AVI:
File Path: F:A Matter of National Securityaudio commentary FINAL.wav
Type: Windows WAVE audio file
File Size: 255.3 MB
Source Audio Format: 48000 Hz - 16 bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:23:14:15660
Average Data Rate: 187 KB / second
File Path: F:A Matter of National SecurityMixed Audio FINAL.wav
File Size: 255.3 MB
plus end credit music:
File Path: F:A Matter of National SecurityAlmost FreeBass.wav
File Size: 12.0 MB
Source Audio Format: 44100 Hz - 16 bit - Mono
Project Audio Format: 48000 Hz - 32 bit floating point - Mono
Total Duration: 00:02:22:16930
Average Data Rate: 86 KB / second
File Path: F:A Matter of National SecurityAlmost FreeDrums.wav
File Size: 24.0 MB
Source Audio Format: 44100 Hz - 16 bit - Stereo
Average Data Rate: 172 KB / second
File Path: F:A Matter of National SecurityAlmost FreeGuitar.wav
File Size: 12.0 MB
File Path: F:A Matter of National SecurityAlmost FreeVocals.wav
File Size: 24.0 MB
In Project Settings, audio settings: set to 48kHz.
You didn't ask about the video, but all of it is DVAVI for the most part. Some is uncompressed AVI elements.
Thanks, Derek
Joe Bowden
on Nov 6, 2007 at 4:39:38 pm
Sorry, I meant the audio settings in Encore, available from the Advanced tab in the Project Settings dialog.
Derek Beck
on Nov 7, 2007 at 5:21:39 am
I seem to have tried it both ways in Encore, Dolby or PCM, with no benefit or apparent affect either way. I have the audio elements themselves set to automatic transcode.
Thanks, Derek
Joe Bowden
on Nov 7, 2007 at 5:29:49 am
If you have two audio tracks and Dolby Digital encoding in Encore, you should be able to manage 7 Mbps for video without getting any errors.
Derek Beck
on Nov 7, 2007 at 5:42:31 am
Thanks for the reply, but I guess I'm not quite following what I should do, other than set Encore to Dolby. Should I still export the mpeg elements from Premiere?
Derek
