Can't import H.264
COW Forums : Adobe Encore DVD
airkogan
Can't import H.264
on Oct 15, 2007 at 4:21:49 pm
I have an H.264 file that I created using Procoder 3.0 that I'm trying to import into Encore and it's not letting me import it. It shows up gray and unimportable when I go to import it. Anybody have any idea?
Alex
Joe Bowden
Re: Can't import H.264
on Oct 15, 2007 at 4:35:42 pm
Which version of Encore are you using?
Joe Bowden
airkogan
on Oct 15, 2007 at 4:44:10 pm
3.0.1.008
airkogan
3.0.1.008
Joe Bowden
on Oct 15, 2007 at 5:31:56 pm
Please provide more detail about the file: its extension, encoding parameters, etc.
airkogan
on Oct 15, 2007 at 7:20:00 pm
The file is an .h264. I'm on an apple and in the finder it says it's a Unix Executable file. The paramaters I set in Procoder were pretty basic and I tried it as a raw H.264 and using an MPEG stream.
Joe Bowden
on Oct 15, 2007 at 7:52:47 pm
Try setting the extension to .mp4.
If it still doesn't import, or has to be re-transcoded, I would suggest more details on encode settings from Procoder.
airkogan
on Oct 15, 2007 at 9:17:41 pm
It didn't open still, so here are the settings from Procoder:
Stream Type: I tried both MPEG 2 Stream and Raw H.264
Video PID 2064
Audio PID 2068
Profile High
Livel 4.1
Size of Coded Video 33
Number of B-Pict 2
1280x720
16:9
Non-Interlaced
CBR 1 Pass
Bitrate 8000 KBPS
Reference Frames: 4
Search Shape 8x8
Entropey Code CABAC
All Checked:
Uses Fast inter and intra decision
Uses Hadamard Transfer
Motion Estimation: Quarter Pixel
Checked:
Write Timestamp
Write Acces Unit Delimiters
Write Sequence end code
That's all. Thanks a lot.
Alex
Joe Bowden
on Oct 15, 2007 at 9:40:55 pm
I assume you were able to select the file in the Import dialog, but it failed to import.
Was there an error dialog of any kind?
airkogan
on Oct 16, 2007 at 12:33:32 am
Actually, I can't even get it to try and import. When I go to select it in import, either as an asset or timeline, it shows up as gray (unselectable). In the finder, it says it's a unix executable file. Very, very weird to me.
Joe Bowden
on Oct 16, 2007 at 4:20:47 am
Whoops, not mp4. Try the .m4v extension...does it import now?
airkogan
on Oct 16, 2007 at 6:16:38 pm
Encore will see it if I change the extention to .m4v, but then I get the error message that it the codec isn't loaded. If it accepts .h264, why would I need to change the extention to something else?
airkogan
on Oct 17, 2007 at 7:47:34 pm
I'm doing lots of experimenting for this, and I'm finding that a lot of files when I try to import them, including some quicktime files, tell me the codec isn't loaded. Is there a way to load these codecs one by one into a foldier or something so that this will be enabled?
Alex
tb5821
on Dec 18, 2007 at 10:37:45 pm
Was this ever solved, I to am trying to import a mp4 and it says the the codec is not installed...??
airkogan
on Dec 18, 2007 at 10:50:49 pm
Yes and no. What I've discovered is that Encore is very finicky about the types of files it will take. You have to use Premiere's export to Encore function to do the H.264 mpeg4 file type. This is an excellent encoder which is basically Main Concept's encoder.
The only other software I found that would create a file that could be opened as that type was Sorenson Squeeze and Telestream Episode, but Encore wants to transcode both and can't read the proper aspect ratio from the file from Sorenson. Make sure you've downloaded the latest Encore and Premiere updates as a new once came out on the sixth. Procoder's H.264 file is useless for this.
It will take an HD MPEG2 from Sorenson and recognize it properly and not transcode it if you should need that.
Tony Bartolucci
on Dec 18, 2007 at 11:06:08 pm
thanks, this all came about I re-exported my movie out of AE as the mp4 - that total file size is 2.5G -and its good quality so I figured Encore wouldn't have an issue with it.
I also have a full res. quicktime (animation codec) file which will import into encore but once encore tries to transcode it freezes. I figured it was because this file is 90GB... so now I'm trying the mp4 but that would import either, but I'll try the updates.
NAPP Boston Member
