Importing projects... possible?
COW Forums : Adobe Encore DVD
on Oct 7, 2007 at 1:14:52 am
I have a series of Encore projects (4 of them) that my client would like on one DVD, with an additional menu to select which week (corresponds to each DVD).
Rather than recreate the menus and timelines and chapter points, is there a way to pull these projects into a single project so I can simply add a menu and match up the links to correspond with each week's root menu? Obviously, Encore won't let me import a project in the project panel but maybe somebody knows a work around?
Or maybe somebody has a different method in mind? Would be a time saver! Thanks.
Mike Browning
Joe Bowden
Re: Importing projects... possible?
on Oct 8, 2007 at 3:00:39 pm
Encore doesn't support importing projects, or having more than one project opened at a time.
The only shortcuts I can offer is you can save your menus as templates, but that doesn't retain button links; and if you set your chapter markers from Premiere, those will be retained when you import the asset into Encore and add it to a timeline.
© 2018 All Rights Reserved
